Thanks for posting, Chris. I had the same problem this week – latest DTPro, latest Snow Leopard, Macbook – and these instructions solved it.
Posting this message so it’s clear this has happened to others and is not a Lion issue…
David
David
Thanks to aedwards’s advice re: the disappearing sorter.
He advised the following: “It would be worth deleting the file ~/Library/Preferences/com.devon-technologies.think-sorter.plist where ~ is your home folder, this should reset the size and position of the sorter. You will not lose the contents or layout of the sorter by doing this.”
This worked and the sorter was back with everything intact.
Thanks
Bryan
