Sorter is not displayed in the menu
The Porter does not appear in the menu on my MacBook Pro (M1). It only works if I display the Porter as a Dock tab. I find this rather annoying and would like to have the Porter in the menu. What can I do?
Welcome @bergkamp78
I’m guessing you have many menubar items already and it’s getting lost. Is this the case?
Yes. When I have my Macbook on my large external monitor, the Porter shows up in the menu. Only on the Macbook it is not visible.
Bartender or something similar might help
@chrillek is spot on here. Running out of menubar space on a smaller form factor device, like a MacBook isn’t unusual.
Now the symbol is displayed. Problem solved, thank you.
Glad to hear it :slight_smile:
