The sorters lets me change its location along the edge of the screen via dragging, but limits me to the right and bottom edges. I would love to put it along the left edge of the screen next to my dock. Is this possible?
Move the dock to a side where the sorter isn’t. Drag the sorter to the left side (leave room for the dock). Put the dock back on the left side. Some people report problems dragging to the dock side when it is right or left. This is one way to avoid that problem.
That works, thanks!
well, archives and search are sure helpful for forgetful folks like me. I was trying to find in the Preferences where you controlled the placement of the sorter. And here it is, right here! Thanks!!!
