Hello,
I use the Devonthink Pro office, and I got some problem about sorter.
If I drag something into my inbox from sorter, my inbox will appear some empty folders in the Devonthink software, and I tried to drag another something, the empty folders appear again, so I get many same empty folders, It is amazingā¦
The empty folders is my own foldiers in my personal. I donāt know why it appear in my inbox when I draged something into my inbox from sorter.
for example, When I draged my file (123.pdf), my inbox appeared empty folders (Apple,BG2,English ā¦)
Thanks for your help
I think I solved the problem,
I uninstalled application and deleted whole files about devonthink, then reinstall, the empty folders donāt appear.
After doing a search on āsorter,ā I found this thread that describes the problem I am currently having. Followed the instructions (~/Library/Application Support/DEVONthink Pro 2/Inbox) but found noting to delete. Does this solution no longer apply? DTPO internal changes since 2013?
