Hello,
I had to reinstall DevonThink Pro 2.0 after the most recent OS update seemed to have corrupted my system. Anyway, since then, I can’t get the sorter to appear.
When I click the check box next to “Show at login” in the Sorter preferences dialog, the box will be checked, but when I leave that screen and return the box is unchecked.
Any advice would be appreciated. Thank you.
Steve
