Sometimes, line spacing errors occur. Notice the ‘headroom’ in the top folder. In normal cases, there should be some free space. But sometimes you see that there’s no empty space at all I don’t know the exact cause.
Welcome @filmhiker
Thanks for the report! Development will have to investigate this. Thanks for your patience and understanding.
Which version of macOS do you use?
MacOS Mjave is in use.This error is especially good when you open two databases. The language of using computer is Korean.I guess there’s a problem with line matching.
Are you able to reproduce this by performing a bunch of actions right after launching the app?
