Can someone point me in the right direction as to how I can set up the following:
I want to search UK sites specifically in and around an area here in the UK and not get the rest of the world.
How do I set up the general parameters.
PS: I am on a learning curve.
Cheers
Do you want to scan a specific website or use a specific search engine? If you want to search some sites, you might have a look at this topic: http://www.devon-technologies.com/phpBB2/viewtopic.php?t=3977
I want to search for certain medical criteria in a specific city are here in UK. For example, if I choose Manchester UK I also get a Manchester Hospital in Dubai.
I am attempting to stay within a specific area geographically and not collect locations in other countries.
As to different engines Country specific I would welcome your advice as to where they are located.
Thanks
You might use secondary search term like…
Manchester NEAR UK
…or…
Manchester NEAR UK BUT NOT NEAR Dubai.
Many thanks,
I’ll give it a go.
