Split Document ("Dokument aufteilen") does not work in 3.9.5
Hi @ all.
Just noted that Split Document(in German “Dokument aufteilen”) does not work properly.
If I mark the second page and right click “Dokument aufteilen” all Pages from here to the end are copied in another new object.
But in original object all pages still existing.
Does anyone have noticed a similar behavior ?
Have a nice Sunday.
regards, michael
Confirmed. Thanks for the report.
Fixed for the next release.
I’ve detected a lot of laziness in synchronise with the sync database for this version as well. Not when losing focus (with that enabled) and not even pressing the Sync all button, DT does nothing. Quit and relaunch is the solution. I’ve gone back to 3.9.4 as well.
What sync method? We have no other such reports.
WebDAV over my Synology NAS with Synology DDNS, but it happens at home and other DDNS services like Synology Drive or Photos works fast. However, I’ve checked now (morning next day) and it is not lazy anymore.
Hi there.
Just installed most recent update.
Split Document works as good as before.
Many thx for the fix.
regards, michael
Thanks for the confirmation.
Cheers!
Can I add my thanks for the fix - much appreciated. :pray: :grinning:
