Split PDFs - Custom Break
Thanks @pete31! I am getting single page PDFs, which contain theDelimiter. The pages between delimiters are being discarded.
I spent a couple of hours trying to understand the logic behind your genius script. I think the difficulty might be in defining thisPDF_LastPage_Index. In the previous script defining the last page was “straightforward”, as it was the page that contained the theDelimiter; so was definining the next starting page: the one right after the previous theDelimiter.
Here, the first page should be the one containing the first instance of theDelimiter, and the last page the one before the next instance of theDelimiter. With my (very) limited understanding of loops, seems tough to get. Nice try though! Thanks!
For the sake of clarity, here are the expected results from the example PDF.
Proceso 31-2891 - 2.pdf (70.5 KB)
Proceso 31-2891 - 3.pdf (70.2 KB)
Proceso 31-2891 - 1.pdf (68.2 KB)
Ok, no idea what I did there …
This one should work
-- Split PDF at delimiter (using the next page after the delimiter as first page)
use AppleScript version "2.4"
use framework "Foundation"
use scripting additions
property theDelimiter : "Proceso 31-2891"
		if theRecords = {} then error "Please select some PDF records."
		show progress indicator "Split PDF at delimiter... " steps (count theRecords) as string with cancel button
			set thisRecord_Type to (type of thisRecord) as string
			if thisRecord_Type is in {"PDF document", "«constant ****pdf »"} then
				set thisRecord_NameWithoutExtension to name without extension of thisRecord
				step progress indicator "... " & thisRecord_NameWithoutExtension
				set thisRecord_Path to path of thisRecord
				set thisRecord_LocationGroup to location group of thisRecord
				set thisRecord_URL to URL of thisRecord
				set theTempDirectoryURL to my splitPDFatDelimiter(thisRecord_Path, thisRecord_NameWithoutExtension, thisRecord_LocationGroup, thisRecord_URL)
		my deleteTempDirectory(theTempDirectoryURL)
		hide progress indicator
		return
on splitPDFatDelimiter(theRecord_Path, theRecord_NameWithoutExtension, theRecord_LocationGroup, theRecord_URL)
		set thePDF to current application's PDFDocument's alloc()'s initWithURL:(current application's |NSURL|'s fileURLWithPath:theRecord_Path)
		set theResultSelections to (thePDF's findString:theDelimiter withOptions:0)
		set theResultSelections_Count to theResultSelections's |count|()
		if theResultSelections_Count = 0 then error "This PDF doesn't contain delimiter \"" & theDelimiter & "\""
		set theTempDirectoryURL to my createTempDirectory()
		set thisPrefix to 0
		repeat with i from 0 to (theResultSelections_Count - 1)
			set thisResultSelection to (theResultSelections's objectAtIndex:i)
			set thisResultSelection_Page_Index to (((thisResultSelection's pages()'s firstObject())'s label()) as integer) - 1 -- "pageAtIndex" is zero based, "label" is not
			if i = 0 then
				set thisPDF_FirstPage_Index to 0
			else
				set thisPDF_FirstPage_Index to thisResultSelection_Page_Index
			if (i < theResultSelections_Count - 1) then
				set theNextResultSelection to (theResultSelections's objectAtIndex:(i + 1))
				set theNextPDF_FirstPage_Index to (((theNextResultSelection's pages()'s firstObject())'s label()) as integer) - 1 -- "pageAtIndex" is zero based, "label" is not
				set thisPDF_LastPage_Index to theNextPDF_FirstPage_Index - 1
			else
				set thisPDF_LastPage_Index to ((thePDF's |pageCount|()) - 1)
			set thisPDF_FirstPage to (thePDF's pageAtIndex:thisPDF_FirstPage_Index)
			set thisPDF_FirstPage_Data to thisPDF_FirstPage's dataRepresentation()
			set thisPDF to (current application's PDFDocument's alloc()'s initWithData:thisPDF_FirstPage_Data)
			set thisPDF_CurrentLastPage_Index to thisPDF_FirstPage_Index as integer
			repeat with i from 1 to ((thisPDF_LastPage_Index as integer) - (thisPDF_FirstPage_Index as integer))
				set thisPDF_CurrentLastPage_Index to thisPDF_CurrentLastPage_Index + 1
				(thisPDF's insertPage:(thePDF's pageAtIndex:thisPDF_CurrentLastPage_Index) atIndex:(thisPDF's |pageCount|()))
			set thisTempURL to ((theTempDirectoryURL's URLByAppendingPathComponent:(current application's NSProcessInfo's processInfo()'s globallyUniqueString()))'s URLByAppendingPathExtension:"pdf")
			(thisPDF's writeToURL:thisTempURL)
			set thisTempPath to (thisTempURL's |path|()) as string
				set thisPrefix to thisPrefix + 1
				set thisImportedRecord_Name to theRecord_NameWithoutExtension & space & "-" & space & (thisPrefix as string)
				set thisImportedRecord to import thisTempPath name thisImportedRecord_Name to theRecord_LocationGroup
				set URL of thisImportedRecord to theRecord_URL
			set theNextFirstPage_Index to thisResultSelection_Page_Index + 1
		return theTempDirectoryURL
		activate
		if the error_number is not -128 then display alert "Error: Handler \"splitPDFatDelimiter\"" message error_message as warning
		error number -128
end splitPDFatDelimiter
on createTempDirectory()
		set theTempDirectoryURL to current application's |NSURL|'s fileURLWithPath:((current application's NSTemporaryDirectory())'s stringByAppendingPathComponent:("_Script - Split PDF at delimiter" & space & (current application's NSProcessInfo's processInfo()'s globallyUniqueString())))
		set {successCreateDir, theError} to current application's NSFileManager's defaultManager's createDirectoryAtURL:theTempDirectoryURL withIntermediateDirectories:false attributes:(missing value) |error|:(reference)
		if theError ≠ missing value then error (theError's localizedDescription() as string)
		activate
		if the error_number is not -128 then display alert "Error: Handler \"createTempDirectory\"" message error_message as warning
		error number -128
end createTempDirectory
on deleteTempDirectory(theTempDirectoryURL)
		set {successDeleteDir, theError} to (current application's NSFileManager's defaultManager()'s removeItemAtURL:(theTempDirectoryURL) |error|:(reference))
		activate
		if the error_number is not -128 then display alert "Error: Handler \"deleteTempDirectory\"" message error_message as warning
		error number -128
end deleteTempDirectory
Worked perfectly!!! Thanks again!
