I have just upgraded from DT2. I never really got going with DT2 though I did use it for a while and I did transfer in a lot of files. All the old files came across into DT3 and I have been attempting to organise but it is a mammoth task.
I would now like to start afresh with DT3 and retain DT2 as an archive for now.
I did the upgrade deal and got a discount for DT3. Am I entitled to have two copies running in parallel for the time being?
What is the easiest way to reset DT3 so it is completely blank?
The purchase or upgrade to DEVONthink 3 comes with two seats - per-machine licenses, so you can install and register it on two Macs.
- Close all the databases in DEVONthink.
- Quit DEVONthink.
- In the Finder, select the Go menu while holding the Option key, then choose Library.
- In the Application Support/DEVONthink 3 directory, move the Inbox.dtBase2 file to another location.
- Launch DEVONthink and a new Global Inbox will be created.
Also, you should delete the DEVONthink 2.x application from your /Applications folder and reboot the machine.
Thanks. I have actually managed to clear DT3 manually just by deleting everything. DT2 is also on my system and this contains all my old files. Is there any reason why I shouldn’t retain DT2 as an archive of my old files? I would like to go through them when I have time but for now just want a fresh start with DT3. I only have one Mac but have purchased DTG for use on iOS. Is having both DT2 and DT3 on my Mac going to mess up sync? Of course I am only trying to sync DT3 not DT2. The reason I am not just putting all the old files into a dedicated db on DT3 is that I don’t really want all the tags cluttering up DT3.
No you shouldn’t keep DEVONthink 2 on the same account, on the same machine. DEVONthink 3 uses the same bundle id as 2 and the operating system can get confused about what app is what.
Also, there is no need to keep 2 when 3 will open the same databases with no issue.
Tags are per-database so the only “clutter” would be when that specific database is open.
But again, opening any particular database in DEVONthink is optional.
