Hello everyone!
I know DTP is predominantly a text-facing tool, but it’s also a great way to keep project folders together.
As a result, I’m finding I need to capture some audio into a DEVONthink group. What I’d love to be able to do is drop a blank/empty audio file into the DT Templates set, so I can just create a new recording in the folder, then open it externally, click a big, fat red button, then save and quit the external editor. The audio recording in DT is then automagically updated (this is the step I’m confident of).
However, looking around, there’s no audio software that I can find that does this. There’s things like Tapedeck and Piezo, but both insist on working with their own document storage ares, which they try to hide from me. Even creating a very short clip of silence in Quicktime and using that as a template no longer allows you to record more audio to it.
Does anyone have any suggestions for something lightweight, cheap, and mac-native that will do this?
Thanks for any light shed!
- Dave
