Hello there,
I have just bought a new Macbook and would like to synchronize my databases from my Mac Mini.
I added a new iCloud location without encryption on the Mini, which I think should be the REMOTE part on the Macbook, right?
Thx
Weizhe Li
Hello there,
Has the mini finished synchronising/uploading to iCloud?
Edit: what I’m saying is that the initial synchronisation can take a while (days…?) and as such the databases won’t be immediately available on other devices (afaik you are correct in assuming they will appear in the location indicated in your capture; that is assuming both devices use the same Apple ID).
Edit 2: and whilst I’m sure you know what you’re doing, do you know what you’re doing? just asking re. the lack of encryption.
Hello Blanc,
Thank you for your kindness. I’ll get my main database encrypted as soon as I find the sample database on my Macbook.
Regards,
Weizhe
