Hi all,
I’ve been syncing databases between DT3 on a '21 iMac and a '15 MacBook as well as with DTTG on a new iPad Air. I haven’t had any issues until today, when a very particular problem happened. Perhaps it’s too particular to garner any help, but I was freaked out, so I thought I would add it here. It has to do with an .rtf.
At the start of the year, I edited this .rtf on both the MacBook and the iMac.
For the past month, I’ve been editing the rtf almost exclusively on the iMac. Last night, I edited the rtf on the iMac, and logged out.
Today, I opened the rtf on the MacBook, and for some reason, it displayed a very old (older than a month) version of this document under the same name, in the same place in the file hierarchy. (I suspect somehow this particular file was not syncing; I don’t know why, because I have not noticed other files not syncing on DT3 on the MacBook.)
I then opened DTTG on my iPad, found the file, opened it (requiring a download first), and it too displayed the old/wrong version also currently on display on my MacBook.
Nervous, I went to the iMac, which is in my office and had been asleep this whole time, unplugged its ethernet to be double sure, logged in, saw the “newer”, correct version of the rtf still up from last night. I immediately copied it / resaved it in two different locations, both on the cloud and on the harddrive. I also made a copy of it in DT3 on the iMac under a new name.
I then reconnected the iMac’s ethernet, and sure enough, the rtf_original_name on the iMac synced, and its “newer”/correct contents were replaced with the contents from the old version currently displaying on the MacBook and iPad.
I’m baffled because all three devices have “duplicate” toggled under sync options for conflicts. I tested this by opening the troubled rtf_original_name on the iPad (with older contents) and began editing it with test lines. I then opened that same rtf_original_name (with older contents) on the iMac, and pasted into it the newer/correct contents. The iPad and the iMac then immediately produced rtf_original_name_copy with the contents displayed on the iPad, as would be expected.
I don’t understand why, initially, this morning, the MacBook’s version would have been able to overwrite the newer version. Any thoughts? And any tips on ways to avoid this kind of issue in the future? Is there any kind of version control possible with DT3?
I hope this was halfway legible—my tech knowledge is such that syncing is more or less black magic to me.
Thanks!
