Sync problem w/ global inbox
My global inboxes in Macbook and iPhone have gotten out of sync. So I did Clean Database, but now it says Not Yet Synchronized, Merge with Remote Database. But there is no Global InBox in the list of my remote databases. Rebooting DT3 doesn’t change anything, same thing w/ Synchronize Database or Verify Database. Any suggestions would be appreciated!
The Global Inbox will never show up as a remote database since it’s always open
And you don’t want to import a Global Inbox. You want to merge it.
Also, the 3.x line is in maintenance and will be retired at some point. Version 4 is the actively developed version and we recommend you upgrade sooner rather than later.
Hi Jim- Yup, I’ve been meaning to upgrade. In the meantime, I need to get this fixed. My iphone is missing items from the past few days. And in my Mac, under local databases it now says Not Yet Synchronized, Upload Database. How do I merge the global inboxes?
Or since I do want to upgrade anyway, would that be the easiest way to get my Macbook and iphone back in sync - and not bother fixing in v3?
Never mind, rebuilding the database fixed the problem. Next step, upgrade to v4 - thanks for the reminder. :slightly_smiling_face:
You’re welcome :slight_smile:
