I’ve followed the instructions, made sure my databases are not housed in Dropbox, established sync locations in Dropbox and locally…but I have 3 databases that just refuse to sync.
When I click on a database and ask it to sync with Dropbox, it starts through the motions and then stops. Nothing apparently syncs. Same if I try to sync to the second computer through a direct connection.
Have you checked the integrity of all your databases, on all your Macs, using Tools > Verify & Repair? If any error is reported, or missing files, clean up the database, e.g., with Tools > Database Rebuild.
If you still have problems, describe the method you are using to Sync and other information that may be useful, in a Support ticket.
Sync worked perfectly between my iMac and MacBook Air via Dropbox until downgrade to 2.7. Still doesn’t work properly even with the latest 2.7.1 installed.
I’m really not very technical computer-wise, so I don’t understand what is going on.
