Sync Problems
I am having problems with DevonThink.
It syncs some of my databases, but not all.
This is what I have done to try to correct it.
  1. I have made sure the name of the database is exactly the same on both computers - for example - business It shows up as business.dtBase2 in finder on both computers
  2. I have all databases under the user name / DevonthinkDB / I do NOT have that username in any type of cloud program.
3 I have created a sync store called 2.dtCloud . I have the same sync store on both computers
d
4. I Open preferences / Sync / , Click the sync store. / . and check the database so it shows as syncing.
Yet on some of the databases, it works beautifully. on others, It does not sync at all.
For example, when I click one database, it shows as 5 KB. On the other computer, it shows as 449.8 MB. And syncing them does nothing to change that.
If I add more files to the smaller database, it grows, but none of the new files shows up on the synced database.
I have gone over this and over this and can’t seem to find what I am doing wrong.
It works great on about 75% of my files.
I am using Dropbox to sync with, but am letting DEVONthink do the sync process.
Any tips or suggestions?
Thanks
Rick
? Have you made databases on each machine but named them the same? If so, this will not Sync them together. See this blog post: blog.devontechnologies.com/2014/ … m-scratch/
