Sync stuck at `1 items left to be uploaded`
Is your database’s Trash emptied?
yes
a toolbar search for item:pending in all databases
Please post a screen capture of this search.
more interesting…!
if the problem is onDTTG side hot to reset “item left to be uploaded” problem?
  • Are you indexing items in DEVONthink?
  • Are you using CloudKit for syncing?
  • Are you using a shallow sync in DEVONthink To Go?
    no
    no
    I was…
    I changed to “download”, apparently with no results
it works now!
I did clean every database on both ios and mac
Just to say I found this thread and having the same problem with 3 files stuck between a shared Database between my MacBook and my iOS iPadOS devices. I used Chris’ search for ‘item:pending’ and found the three rogue files - they had a cloud against them and refused to download. The files were not critical, so I simply clicked on them, hit ‘reveal’ and deleted them one by one. Problems solved.
just adding how I fixed it as an option for people with a small number of troublesome foes.
Joe
