Here’s the scenario: You have a bunch of files on disk that you’ve tagged using Leap. You’ve also configured Leap to write those tags out as Spotlight comments, so you can search for them quickly with the Finder. This means your files have comments like “&python &script” and such.
You then index/import this collection of files into DEVONthink. If you’ve configured “Preferences | Import | Import Finder comments” in DEVONthink, you’ll notice that your record comments are now the same as your Finder comments were. And if you enabled Spotlight indexing for your DEVONthink database, you’ll find you can still search with “&python” just as you could before in the Finder. All very cool!
The next step is to automate the creation of tag “groups” in DEVONthink, and the replication of tagged records into these groups. That’s what the attached script is for.
This script can take a LONG time to run, so it should probably be used only once after each major import. It assumes the existence of a group named “Tags” at the root level of your database. Please change the script if you don’t like this name. Once you run the script, it will populate this “Tags” group with a bunch of subgroups – one for each tag you had applied to your records. The tags have to be in the form “&tag”, which is what popular tools like Quicksilver, TagBot, Nifty Box, Leap, etc., are used to.
Be sure to see my next post, “Assigning tags in DTP”, which automates the assigning of tags to records once you have such a tag group setup.
John
Synchronize tags.scpt
Version 1.0
by John Wiegley <johnw@newartisans.com>
-- This is the global location of the Tags hierarchy; customize to your tastes!
set tagsPath to "/Tags"
on scanChildren(tagsPath, tagsRecord, theRecord)
if id of theRecord is not the id of tagsRecord then
repeat with theChild in children of theRecord
if type of theChild is group then
my scanChildren(tagsPath, tagsRecord, theChild)
else
step progress indicator (name of theChild as string)
set theComment to comment of theChild
if theComment is not "" then
repeat with childTag in text items of theComment
if texts 1 thru 1 of childTag is "&" then
set childTag to texts 2 thru -1 of childTag
set tagPath to tagsPath & "/" & childTag
if not (exists record at tagPath) then
set childTagRecord to ¬
create record with {name:childTag, type:group} ¬
in tagsRecord
else
set childTagRecord to get record at tagPath
if not (exists record at (tagPath & "/" & name of theChild)) then
replicate record theChild to childTagRecord
end scanChildren
-- Setup a progress indicator so that the user knows when to expect completion.
-- This process could take a VERY long time!
show progress indicator ¬
"Synchronizing tags" cancel button true ¬
steps count of contents of front database
-- Set up our globals and begin the recursive process
set tid to AppleScript's text item delimiters
set AppleScript's text item delimiters to space
set theRoot to root of front database
my scanChildren(tagsPath, get record at tagsPath, theRoot)
-- If any errors occur, let the user know with a nice dialog
display alert "DEVONthink Pro" message error_message
on error number error_number
if error_number is -1708 then
display dialog error_message buttons {"OK"} default button 1
-- Restore the environment on our way out, whether things succeeded or not
set AppleScript's text item delimiters to tid
hide progress indicator
