47 mb. I later thought that I just pasted the data base of the other computer into the documents file. Maybe I have to import it to get it to register with DTOP.
I changed the place of a file. 59 kb moved.
It seems I have to have both computer on and DTOP also has to be running in order to Sync. That is a pretty tall order.
I have unlimited webspace with my webhost. Maybe I should sync everything there and then Sync it again to the other computer. That way I can be doing it all the time and I don’t have to continually have both computers running. Is that a possible set up?
A Direct Connection Sync requires both machines to be on and running DEVONthink.
You would import the database from one machine to the other via the Direct Connection.
If your hosting service has WebDAV, it’s possible to use that as a Sync mechanism that wouldn’t require both machines to be on.
Both DT on both computers are open.
On computer A the connection is being made. On computer B, the log says "Could not open the connection (The operation could not be completed.) " So, that means that something is wrong with the connection on Computer B and I should mimick the connection on Computer A?
