I have a desktop and a pc and want to sync several DT databases by direct connection.
If I use the same direct connection location (Johns-MacBook-Pro.local.) to sync several databases, will this merge the databases?
If the database exists and is open when you do a Preferences > Sync > Import Database…, you will be asked if you want to merge them.
