Tags for a specific group
Hi!
I found this post from 2017 but I was wondering if there is any update on this.
I have a group where I throw all of my computer stuff. The group is creatively called “Computer”. I’ve been tagging all of the documents that I put in the group. I’d like to view a list of the tags in the Computer group only. But I can’t find a way to do it. I don’t even really want to go to the documents or anything, I just want to know what tags have been used in this group. Some sort of smart group or rule or something?
Thanks!
Select the group and activate the “tag” column in list view?
You can also select a group and click the tags button at the bottom of the sidebar. As you click on the listed tags, the file/group list will show only items containing all selected tags. It’s displayed like a word cloud so you can see which tags are most common.
To dismiss the tag filter (tag explorer?) click the tags button a second time.
The Tags filter pane, also available via the Tools > Filter pane.
Brilliant! Exactly what I was looking for! Thanks so much!
