Hi!
After installing the DT3 beta and opening all my old DTPO databases in it, I found that my DEVONthink tags were now all also available as macOS tags, visible in the Finder.
However, instead of being applied to the documents that I tagged within DT, the macOS tags were all applied to the .dt3
metadata files under ~/Library/Metadata/com.devon-technologies.think3
Completely deleting the tag in macOS (i.e. removing it from all files) does not remove the tag from DT — so that’s good.
Creating a new tag inside DT does not cause the tag to be created in macOS. It only happened to the pre-existing tags when I imported/upgraded my databases.
