Tags not showing
Normally I can see my tags at the bottom of my 3 pane view. They are no longer appearing. As you can see in the screenshot, I have “show tags” selected under View. They also appear in the side bar. How do I get them back? I prefer entering them at the bottom of the viewing panel.
It seems you have selected an item on the side bar and not an item or group in the main window. If you select an item or group in the main window, you will see the tags. Sidebar works a bit differently from the the side panel of the 3-pane view in DT2.
Well doh! Thank you so much, that was a quick fix :slight_smile:
