Take Note is supposed to send the note to the default destination (per release notes and manual) - yet it ignores the “select group” setting if for default destination - in that case using the global inbox instead of prompting for group. Can this get fixed?
A future revision will probably add the possibility to select the destination group to the Take Note panel (as it’s an internal command and therefore doesn’t use the group selector), e.g. via a popup menu.
Thank you!
