Definitely. Personally, I’d also get rid of all these these, those, this, that, the etc. Never got the point of them (wow, never saw a “them” actually in AS code).
Yes, that’s correct.
I love this script @pete31 - it feels like proper magic
I’ve updated the script so you can give it a list containing search terms and a comment and it will add it back to the PDF like such:
property theHighlightColorIndex : 1 -- set a color, Preferences > Colors > Highlighting
set thePath to path of first item of (selection as list)
set itemA to {"Something very important", "Check out these references"}
set itemB to {"A sentence to highlight", "Don't forget this"}
set theHighlightItems to {itemA, itemB}
my addHighlightAnnotations(thePath, theHighlightItems, theHighlightColorIndex)
There might be some tweaking needed at some point removing some current application references as well as juggling lists and arrays, but it works exactly like expected for now.
Updated script
use AppleScript version "2.4"
use framework "Foundation"
use framework "Quartz"
use scripting additions
on addHighlightAnnotations(thePath, theItems, theHighlightColorIndex)
set thePDF to current application's PDFDocument's alloc()'s initWithURL:(current application's |NSURL|'s fileURLWithPath:thePath)
set theItems to (current application's NSArray's arrayWithArray:theItems)
set theSelectionsArray to current application's NSMutableArray's new()
repeat with i from 0 to ((theItems's |count|()) - 1)
set thisItem to (theItems's objectAtIndex:i)
set thisSearchTerm to ((current application's NSArray's arrayWithArray:thisItem)'s objectAtIndex:0)
set thisComment to ((current application's NSArray's arrayWithArray:thisItem)'s objectAtIndex:1)
set theResultSelections to (thePDF's findString:thisSearchTerm withOptions:0)
if theResultSelections's |count|() ≠ 0 then
set theSelectionsArray to my addSelectionToSelectionsArray(thisSearchTerm, theResultSelections, thisComment, theSelectionsArray)
else
set thisSearchTerm_Components to (thisSearchTerm's componentsSeparatedByString:space)
repeat with j from 0 to ((thisSearchTerm_Components's |count|()) - 1)
set theseSearchTerm_Components_1 to (thisSearchTerm_Components's subarrayWithRange:{0, (thisSearchTerm_Components's |count|()) - j})
set thisSearchTerm_Part_1 to (theseSearchTerm_Components_1's componentsJoinedByString:space)
set theResultSelections to (thePDF's findString:thisSearchTerm_Part_1 withOptions:0)
set theSelectionsArray to my addSelectionToSelectionsArray(thisSearchTerm_Part_1, theResultSelections, thisComment, theSelectionsArray)
set thisLocation to (theseSearchTerm_Components_1's |count|())
set thisLength to (thisSearchTerm_Components's |count|()) - thisLocation
set theseSearchTerm_Components_2 to (thisSearchTerm_Components's subarrayWithRange:{thisLocation, thisLength})
set thisSearchTerm_Part_2 to (theseSearchTerm_Components_2's componentsJoinedByString:space)
set theResultSelections to (thePDF's findString:thisSearchTerm_Part_2 withOptions:0)
set theSelectionsArray to my addSelectionToSelectionsArray(thisSearchTerm_Part_2, theResultSelections, thisComment, theSelectionsArray)
exit repeat
set theDeeperLookArray to current application's NSMutableArray's new()
set thisSearchTerm to ((current application's NSArray's arrayWithArray:(theItems's objectAtIndex:i))'s objectAtIndex:0)
repeat with j from 0 to ((theItems's |count|()) - 1)
set thatSearchTerm to ((current application's NSArray's arrayWithArray:(theItems's objectAtIndex:j))'s objectAtIndex:0)
if (thisSearchTerm's containsString:thatSearchTerm) and not (thisSearchTerm's isEqualTo:thatSearchTerm) then
(theDeeperLookArray's addObject:thatSearchTerm)
if theHighlightColorIndex < 1 or theHighlightColorIndex > 7 then error "No valid HighlightColor index. Valid: 1-7"
if current application's id = "com.devon-technologies.think3" then
set theDefaults to current application's NSUserDefaults's standardUserDefaults()
else
set theDefaults to current application's NSUserDefaults's alloc()'s initWithSuiteName:"com.devon-technologies.think3"
set theDictionary to (theDefaults's dictionaryRepresentation())'s dictionaryWithValuesForKeys:{"HighlightColor-0", "HighlightColor-1", "HighlightColor-2", "HighlightColor-3", "HighlightColor-4", "HighlightColor-5", "HighlightColor-6"}
set theColorDictionary to theDictionary's objectForKey:("HighlightColor-" & ((theHighlightColorIndex - 1) as string))
set theRed to current application's NSNumber's numberWithDouble:((theColorDictionary's valueForKey:"red"))
set theGreen to current application's NSNumber's numberWithDouble:((theColorDictionary's valueForKey:"green"))
set theBlue to current application's NSNumber's numberWithDouble:((theColorDictionary's valueForKey:"blue"))
set theAlpha to current application's NSNumber's numberWithDouble:((theColorDictionary's valueForKey:"alpha"))
set theHighlightColor to current application's NSColor's colorWithCalibratedRed:theRed green:theGreen blue:theBlue alpha:theAlpha
set theDocumentAuthor to (theDefaults's dictionaryRepresentation())'s stringForKey:"DocumentAuthor"
set theAnnotationSubtype to current application's PDFAnnotationSubtypeHighlight
set theAnnotationProperties to current application's NSMutableDictionary's new()
(theAnnotationProperties's setObject:theHighlightColor forKey:(current application's PDFAnnotationKeyColor))
repeat with i from 0 to ((theSelectionsArray's |count|()) - 1)
set thisItem to (theSelectionsArray's objectAtIndex:i)
set thisSearchTerm to (thisItem's valueForKey:"SearchTerm")
set thisComment to (thisItem's valueForKey:"Comment")
set thisResultSelection_BoundsForPage to (thisItem's valueForKey:"Selection_BoundsForPage")
set thisResultSelection_Lines_QuadPointsArray to (thisItem's valueForKey:"Selection_Lines_QuadPoints")
set createAnnotation to true
if (theDeeperLookArray's containsObject:thisSearchTerm) then
set thisResultSelection_Page_Label to (thisItem's valueForKey:"Selection_Page_Label")
set thisSelectionsArray_filtered to (theSelectionsArray's filteredArrayUsingPredicate:(current application's NSPredicate's predicateWithFormat:("self.Selection_Page_Label = " & quoted form of (thisResultSelection_Page_Label as string) & " AND " & "self.SearchTerm CONTAINS " & quoted form of (thisSearchTerm as string) & " AND " & "!self.SearchTerm = " & quoted form of (thisSearchTerm as string))))
repeat with j from 0 to ((thisSelectionsArray_filtered's |count|()) - 1)
set thatItem to (thisSelectionsArray_filtered's objectAtIndex:j)
set thatResultSelection_BoundsForPage to (thatItem's valueForKey:"Selection_BoundsForPage")
set thatResultSelection_Lines_QuadPointsArray to (thatItem's valueForKey:"Selection_Lines_QuadPoints")
set intersectsBoundsForPage to current application's NSIntersectsRect(thisResultSelection_BoundsForPage, thatResultSelection_BoundsForPage)
if intersectsBoundsForPage then
repeat with k from 0 to ((thisResultSelection_Lines_QuadPointsArray's |count|()) - 1) by 4
set thisResultSelection_Line_QuadPoints to (thisResultSelection_Lines_QuadPointsArray's subarrayWithRange:{k, 4})
set thisResultSelection_Line_Bounds to my makeRect(thisResultSelection_Line_QuadPoints)
repeat with l from 0 to ((thatResultSelection_Lines_QuadPointsArray's |count|()) - 1) by 4
set thatResultSelection_Line_QuadPoints to (thatResultSelection_Lines_QuadPointsArray's subarrayWithRange:{l, 4})
set thatResultSelection_Line_Bounds to my makeRect(thatResultSelection_Line_QuadPoints)
set intersectsBoundsForLine to current application's NSIntersectsRect(thisResultSelection_Line_Bounds, thatResultSelection_Line_Bounds)
if intersectsBoundsForLine then
set createAnnotation to false
exit repeat
if intersectsBoundsForLine then exit repeat
if createAnnotation then
set thisDate to (current application's NSDate's |date|())
(theAnnotationProperties's setObject:thisDate forKey:(current application's PDFAnnotationKeyDate))
set thisAnnotation to (current application's PDFAnnotation's alloc()'s initWithBounds:(thisResultSelection_BoundsForPage) forType:theAnnotationSubtype withProperties:theAnnotationProperties)
set thisAnnotation_QuadPoints to current application's NSMutableArray's new()
repeat with i from 0 to ((thisResultSelection_Lines_QuadPointsArray's |count|()) - 1)
(thisAnnotation_QuadPoints's addObject:(current application's NSValue's valueWithPoint:(thisResultSelection_Lines_QuadPointsArray's objectAtIndex:i)))
(thisAnnotation's setValue:(thisAnnotation_QuadPoints) forAnnotationKey:(current application's PDFAnnotationKeyQuadPoints))
if not (theDocumentAuthor's isEqualTo:"") then (thisAnnotation's setUserName:theDocumentAuthor)
set thisResultSelection_Page to (thisItem's valueForKey:"Selection_Page")
-- add popup
set popupAnnotationSubtype to current application's PDFAnnotationSubtypePopup
set popupAnnotation to (current application's PDFAnnotation's alloc()'s initWithBounds:(thisResultSelection_BoundsForPage) forType:popupAnnotationSubtype withProperties:theAnnotationProperties)
(thisAnnotation's setValue:thisComment forAnnotationKey:(current application's PDFAnnotationKeyContents))
(thisAnnotation's setValue:popupAnnotation forAnnotationKey:(current application's PDFAnnotationKeyPopup))
(thisResultSelection_Page's addAnnotation:thisAnnotation)
thePDF's writeToFile:thePath
activate
if the error_number is not -128 then display alert "Error: Handler \"addHighlightAnnotations\"" message error_message as warning
error number -128
end addHighlightAnnotations
on addSelectionToSelectionsArray(thisSearchTerm, theResultSelections, theComment, theSelectionsArray)
repeat with i from 0 to ((theResultSelections's |count|()) - 1)
set thisResultSelection to (theResultSelections's objectAtIndex:i)
set thisResultSelection_Pages to thisResultSelection's pages()
repeat with j from 0 to ((thisResultSelection_Pages's |count|()) - 1)
set thisResultSelection_Page to (thisResultSelection_Pages's objectAtIndex:j)
set thisResultSelection_BoundsForPage to (thisResultSelection's boundsForPage:thisResultSelection_Page)
set thisResultSelection_Lines to thisResultSelection's selectionsByLine
set thisResultSelection_Lines_QuadPointsArray to current application's NSMutableArray's new()
repeat with k from 0 to ((thisResultSelection_Lines's |count|()) - 1)
set thisResultSelection_Line to (thisResultSelection_Lines's objectAtIndex:k)
set thisResultSelection_Line_Page to (thisResultSelection_Line's pages())'s firstObject()
if (thisResultSelection_Line_Page's isEqualTo:thisResultSelection_Page) then
set thisResultSelection_Line_BoundsForPage to (thisResultSelection_Line's boundsForPage:thisResultSelection_Line_Page)
set thisResultSelection_Line_BoundsForPage to current application's NSRect's NSInsetRect(thisResultSelection_Line_BoundsForPage, -1, -1) -- DEVONthink recognizes text more reliably
set MinX to current application's NSRect's NSMinX(thisResultSelection_Line_BoundsForPage)
set MinY to current application's NSRect's NSMinY(thisResultSelection_Line_BoundsForPage)
set MaxX to current application's NSRect's NSMaxX(thisResultSelection_Line_BoundsForPage)
set MaxY to current application's NSRect's NSMaxY(thisResultSelection_Line_BoundsForPage)
(thisResultSelection_Lines_QuadPointsArray's addObject:{MinX, MaxY})
(thisResultSelection_Lines_QuadPointsArray's addObject:{MaxX, MaxY})
(thisResultSelection_Lines_QuadPointsArray's addObject:{MinX, MinY})
(thisResultSelection_Lines_QuadPointsArray's addObject:{MaxX, MinY})
set thisResultSelection_Page_Label to thisResultSelection_Page's label()
(theSelectionsArray's addObject:{Selection_Page:thisResultSelection_Page, Selection_Page_Label:thisResultSelection_Page_Label, Selection_BoundsForPage:thisResultSelection_BoundsForPage, Selection_Lines_QuadPoints:thisResultSelection_Lines_QuadPointsArray, SearchTerm:thisSearchTerm, Comment:theComment})
return theSelectionsArray
activate
if the error_number is not -128 then display alert "Error: Handler \"addSelectionToSelectionsArray\"" message error_message as warning
error number -128
end addSelectionToSelectionsArray
on makeRect(theSelection_QuadPoints)
set theSelection_QuadPoints to (theSelection_QuadPoints as list)
set MinX to theSelection_QuadPoints's item 1's item 1
set MinY to theSelection_QuadPoints's item 3's item 2
set theWidth to (theSelection_QuadPoints's item 2's item 1) - MinX
set theHeight to (theSelection_QuadPoints's item 1's item 2) - MinY
set theRect to current application's NSRect's NSMakeRect(MinX, MinY, theWidth, theHeight)
activate
if the error_number is not -128 then display alert "Error: Handler \"makeRect\"" message error_message as warning
error number -128
end makeRect
on tid(theInput, theDelimiter)
set AppleScript's text item delimiters to theDelimiter
if class of theInput = text then
set theOutput to text items of theInput
else if class of theInput = list then
set theOutput to theInput as text
return theOutput
end tid
Glad it’s useful. You wrote
and I’m wondering in what situation that would be necessary. Does it perhaps have something to do with PDFs that got corrupted by PDFKit (i.e. applying annotations of a corrupted PDF to a new PDF)?
I’m wondering as well, especially since you can already convert a sheet into a PDF. ![]()
Sorry this might be a bit confusing, I mean applying the individual items of the TSV (the highlights and notes) as highlights and notes back to the accompanying PDF.
No - it’s a different workflow altogether. I’m clipping everything I find for reference to PDF and automatically create annotations in Markdown. After that I most times read the PDF and highlight + take notes (in DT or on other devices). Highlights and notes get extracted to the annotation file again. That works well.
But there’s also another type of reading where after clipping I continue reading the webpage and going through it I add selection of the webpage to the annotation file (by appending them). Those annotations obviously are not present in the PDF. I’m using this script to add them afterwards as highlights so I’m keeping my annotation file and highlights in sync. Also this means PDF become portable and have all the relevant content, even without the annotation file.
