I used the index function on some of the folders . It sure is fast but once you index the contents of a folder it doesn’t seem to update the contents. For example if I add a new doc into the folder or remove one nothing happens in DT. I could not find an option to “update” indexing. Of course I can re-index but that causes the whole folder to be copied again and not convenient especially if you are moving things around.
Any solutions to this? Should I forget about indexing on dynamic folders?
