Transclusion with bullet point
Hello all,
Is there a way to use transclusion of a note with bullet points or paragraphs within a table of another Note?
e.g Note A has paragraph and bullet points
Note B has a table and in one of the cells has {{Note A}} .
When I tried, it only gives me the 1st line.
Thank you.
As far as I know cells in MultiMarkdown tables do not support linebreaks, only by using <br/> instead but that’s just a workaround.
Thank you.
That is correct. But it doesn’t work, even if the <br/> is hardcoded into the document to be transcluded.
