Hello, I have never tried to set up Bonjour syncing before, so maybe I’m doing something wrong…
I have no sync locations set up on DTTG right now. I went into Settings, Bonjour/Set options, and the Enable incoming connections is turned off. I am unable to switch it on. I have Bonjour turned on on my Mac DTPO instance. Is there some other setting I need to change to allow this to be enabled?
Thanks.
