It would be great if we could set a universal CSS stylesheet to display MarkDown files – that way we do not need to do it for each and every MarkDown file individually.
Thanks for the suggestion. We may implement this inupcoming releases. However, note you can add a link to a stylesheet and save it out as a template.
Thanks. I think it would be best to have a “set it and forget it” system.
Ideally there would be a setting to put CSS code, and this is included in each MarkDown file throughout the database (i.e. it would sync to DTTG).
That’s pretty much what I just described, even extending to adding internal styling instead of linking the stylesheet. The template would contain this information, so it would be available when you used it in DEVONthink.
