I’m trying to create a smart group that captures a replica of any note containing “S Curve”. It appears the existing scripts will capture any notes that contain the words listed but they don’t have to be contiguous so I end up with a lot of material I don’t want.
I tried putting quotes around “S Curves” but I still end up with any note that has the word curves and S in it.
Does anyone know if there is a way to solve this problem other than:
- Using “All Words checked” too much work to check the ones I want.
- Writing a new script, I don’t think I’m smart enough to create a script to do this, even assuming its possible.
Any suggestions would be appreciatd.
Richard Bullen
