Hi!
I’m a journalist in need of a reference database. I need somewhere to place ideas, random notes, highlights from articles I’ve read, web pages, pdf-documents and images, etc . Stuff that I need right now or might need in a year or two.
I’ve tried DT a couple of times before, but it never stuck with me. With the new sync I’ve decided to give DT a serious chance. But before I dive in and try to set things up myself, I would appreciate any input on how to have DT store what I need.
What I need to store
- Plain text notes I create myself.
- Plain text notes that I create using this Ifttt recipe (https://ifttt.com/recipes/455089-instapaper-highlights-to-dropbox), which takes highlights I make in Instapaper and stores them as individual plain text notes on my Dropbox account.
- Academic papers in pdf format (that I want to both read and annotate)
- Offline copies of web pages
- Images
Devices in use
I want to use my reference database on OS X, iPad and iPhone.
Questions
- To me, all of the information I want to store is treated the same, it’s stuff that I need in my work. So it seems natural to have just one database. But is there a reason to split things in more than one?
- Indexing vs importing – when is either the better choice?
- If a folder is indexed, I can still access the files outside of DT which means that they are available for backup as individual files. If I import stuff into the database, am I running any risk of a total corruption of the database, loosing everything?
- One of the reasons I like plain text files and pdf:s is that there is minimal lockin. That I have everything in those formats today is the reason I can consider trying DT in the first place. If I import files into the DT database, am I loosing this possibility for the future or can files easily be exported in their native file format to a directory structure on my harddrive?
- Can DT monitor certain folders (like the Dropbox folder with plain text highlights from Instapaper) and import every new file that goes into it?
- Dropbox seems like the best sync store option for me. A lot of my plain text files are already on Dropbox. Can DTTG access them directly, or should I still create a sync store on Dropbox? From what I’ve read in the documentation, the answer is yes, in part because of sync performance and stability. If I go with indexing, can the content of the plaintext files still be accessed on DTTG?
- Can DT monitor RSS feeds and create offline copies of every URL in the feed? I’m collecting bookmarks on Pinboard and would like to have them archived in Devonthink as well.
- Can DT import bookmarks from text files in Netscape bookmarks file format?
- Does any DT edition do OCR in jpegs?
- What format for web pages – web archive or pdfs – do you recommend? Currently I’m doing this with EagleFiler, as web archives.
A lot of questions. Any input much appreciated!
Thanks,
Anders
