Mellel is my first choice of word processor and DEVONThink 3 displays file contents perfectly. However, DEVONThink To Go does not and I need to convert files to another format, RTF for example.
Is is possible that DEVONThink To Go could render Mellel files readable in the near future?
Welcome @tfwthg
Also note RTF files aren’t mobile-native so third-party frameworks are used to work with them. There is some support for the in DEVONthink To Go via a framework. However, RTFD can be displayed but not edited in DEVONthink To Go.
Can you suggest an editor that will allow editing of simply-formated text on an iPhone/iPad? I just edited on iPhone such a file and the formatting was deleted.
Yes, clarify. I had three styles with different size fonts, text colour and paragraph margins. Mellel exports an rtf file that looks identical to the original. Editing that rtf using the built in editor in DEVONThink To GO gives only one colour, black, and all identical margins. So, effectively the former styles are lost.
