I’m a new DT user and struggling a bit with how to scan documents to get a PDF AND text.
The machine is connected and set in DT to be the default app. I can get a pdf, but not the ocr - as far as I can see.
Cheers
Cheers
Check SnanSnap Manager’s Settings. If DT Pro is not set as the application, set it to receive scans.
Select a PDF that has been scanned, OCR’d and saved to your database. Now open its Info panel and look at the Kind field. If it says PDF +Text it now contains searchable text, and that’s the desired result of OCR.
I’ll go and try that tonight. Hectic week, I’ve done no learning at all this week.
Cheers
… that the document is marked as PDF (only PDF). Is there something in the scan settings that I need to do to have it do both? Is OCR built in to DT or do I need a separate package?
Thanks
OCR is built into DT Pro Office, but not into DT Pro.
See the feature comparisons at http://www.devon-technologies.com/products/devonthink/comparison.html.
I have DT Prof Office.
I have just had another play and made it work. Not sure what I did last time.
Thanks for the help…
Graham
