Dear,
I use a combined DTPro and DTTG setup. What I would love to do is to use my iPad as my primary device.
What I am currently lacking (or maybe just overseeing) is the ability to have the info pane (long press on the list item or pressing the “three dots”) permanently visible and not being in front of the document.
Is this somehow possible?
Thank you in advance,
best regards
Connor
Sorry but no, there is only the popup. There is not static inspector pane.
Thank you for your feedback.
A pity (at least for me) - but I will adapt accordingly.
However - keep up your great work and product!
You’re welcome and thanks for the kind words!
