Web archive highlighting is too dark
I have my highlighter colors set up the way I want them and they work wonderfully when I’m highlighting a PDF. However, when I use those same highlight colors on web archive documents, the colors are so dark that the text becomes almost illegible. Is there a way to fix this? I have attached an example of a PDF highlight vs a web archive highlight.
I’ve searched the forum and can’t quite find another topic discussing this issue.
Do you use dark mode while highlighting?
I didn’t think I was using dark mode because the background was still white, but when I went into settings and turned dark mode off that fixed it. Thanks.
I wish the program was smart enough to know what color the actual background was instead of defaulting to a darker color that doesn’t work in this particular context, but I get why that might be tricky.
