Version 3.8 changed WebClip behavior:
Select text in browser (Firefox)
press bookmarklet Clip to DEVONthink
WebClip window opens but now
selected text is put in Comments section (instead of BODY)
complete article text is saved in Body section (no need as I only want to save selected text)
How to get previous WebClip behavior? WebClip should
put selected text in BODY section
keep comments section empty
yes: Take Plain Note and “Selection” bookmarklet have desired behavior, BUT
the file is saved directly into INBOX without showing WebClip pop-up window (fast and convenient way to customize tags, title, location, etc…)
Getting closer… but this way invokes smaller pop-up window which doesn’t allow to change URL and BODY
The ideal way would be to have the ability to invoke WebClip TakeNote pop-up window (which should be populated with Title, Body (selected text), URL)
