At the moment I sync my database to a local sync store which is in a Bittorrent folder that syncs with work. I sync the databases when I open and close DT.
The problem is the wait for the sync to take place. It puts me off wanting to open DT because I know it wont be instant and I have to wait for the sync.
So I wondered what would be the best sync schedule. Would an hourly sync suit my needs? I am reluctant to use hourly thinking that if I open DT for 30 mins, it wont sync, then over time I have this large difference between the local sync store. Its why I sync on open and close. But the time is offputting.
So just wondered if there is a working sync setup that means my DT will open instantly.
What about not showing the sync window, which is the main issue I suppose. So put that in the background, or dock it in the app? Can I do that? Not seeing the sync process will mean I think the app is open and ready to go right away.
Will an SSD speed this up? I have been considering upgrading my drive to a SSD.
Thanks
