What is happening for these dialog box selections?
I do not understand what is happening in these two situations:
Start at the root level.
  • Click the + button --> dialog box with text frame appears
  • Select Media, then reselect Text --> the text frame is the same as above
  • Select Group, then reselect Text --> the text frame is now different in appearance
  • Select Sheet --> does not allow this selection to happen
  • Select Sheet again --> becomes “selected” but appearance is as though text is to be entered
(DTTG on iPad)
JJW
Yes, that last results seems to be a glitch
Doesn’t happen over here in DEVONthink to Go 2.4 (16199) – the selection happens as expected
Again, doesn’t happen over here in DEVONthink to Go 2.4 (16199) – the selection happens as expected
I am using 2.4 (16201)
JJW
