Which browser engine does DA use internally? Is it Safari’s webkit?
If so browsing speed can be even more improved by using the nightly webkit builds.
Both DEVONagent and DEVONthink use the system’s WebKit framework.
you’ve raised a question that i thought about. Say i download the nightly webkit; i run it (then it behaves as safari without SIMBL).
how do i apply the use of the webkit to da or dtp?
thanks,
marc
