Based on the Add Suffix To Names script I have written a script to remove the extension from the visible name of a record:
if this_selection is {} then error "Please select some contents."
set res to display dialog "Remove extension from " & (count of this_selection) & " documents?"
if button returned of res is "ok" then
repeat with this_item in this_selection
set current_name to the name of this_item
set new_item_name to remove_extension(current_name as string)
set the name of this_item to new_item_name
on remove_extension(this_name)
if this_name contains "." then
set this_name to ¬
(the reverse of every character of this_name) as string
set x to the offset of "." in this_name
set this_name to (characters (x + 1) thru -1 of this_name) as string
set this_name to (the reverse of every character of this_name) as string
return this_name
end remove_extension
Activated in DEVONthink it returns always the error DEVONthink Pro got an error: Can’t continue remove_extension.
However when I run the subroutine remove_extension in a standalone script from Script Editor it works fine.
What’s going wrong? Type issue with this_selection?
