I just read the manual and don’t understand the difference between Wiki and static links.
Thanks
Thanks
Wiki Links are created automatically when you either type the name of a group or a file (or its mashed form), whereas static links need to be created by highlighting a text passage, select “make link” and then point it to the linked location.
Thus you can never ™ have a wiki-link pointing to something that is not also called that way, i.e. “Mr. Oizo” as a link will always point to a file named “Mr. Oizo” (or at least a file that has that alias).
A static link could have the text “Mr. Oizo”, but point to the File “Jeffrey Sinclair” instead. (You could achieve that as well with a wiki link by using an alias).
Or, putting it in other words:
(erm, is there more to this? what happens with static links when a file is renamed?)
