WikiLinks don't show in Incoming Links Panel
When mixing Chinese with English or numbers, the Incoming Links in Inspectors shows nothing. It is reflected in the lower half of the picture.
If the file name is full of Chinese characters, it can also be displayed normally.
:white_check_mark::Display normal
:cross_mark::Unable to display
The upper part of the image presents two special cases, which have minimal impact and are provided for reference only.
Results and related settings
Thank you for the bug report! Could you please zip the used files and upload them so that we could easily check this on our own? Or just send them via PM. Thanks!
Wikilinks Test.zip (9.9 KB)
F.Y.I.
Sorry, because the following document has set a non-Chinese alias, I forgot to delete it after testing yesterday. Please pay attention to remove the alias when you check it.
In addition, those two special cases (Indicated by the red arrow in the first picture) can also be displayed normally after clicking WikiLinks to create a new file today.
F.Y.I.
Could you please export the files via File > Export > Files & Folders… again so that original names & metadata are preserved? The filenames in the unzipped archive are not the original ones. Just ensure that the new Zip file contains the file DEVONtech_storage
Export.zip (13.6 KB)
I’m afraid that the file name containing many punctuation marks cannot be maintained after being exported to Finder. It is recommended to copy the content in the Wiki.md file to create a new corresponding file.
F.Y.I.
Thank you for the file! The issue is caused by both file extensions (ideally Wiki links don’t use any) and using Asian & Latin characters/numbers in names (a limitation of the search index). The next release will fix at least the first issue.
Great! Thank you so much~
