I really like the wikilinks feature in DT3, in particular because it allows me to link between .txt files that I would otherwise not be able to link from (only notes in RTF, formated note and HTML feature the hyperlink option).
However, I’ve noticed that unlike the regular hyperlinks, wikilinks are not being displayed in the document links pane.
Thank you. Can I also point out that WikiLinks are not being reported in TXT files either eventhough the wikilinks themselves are working in TXT.
Thank you very much for pointing this out as I hadn’t tried it with md files. This is helpful as I can convert other text files to Markdown for the time being and get the links indexed.
Apologies, I missed the reply and I just saw it! Meanwhile, the workaround I’ve used for WikiLinks is to convert all the files to markdown, since WikiLinks in md are being reported. A bit cumbersome, but gets the job done.
As in previous betas, in DT3 beta 7 Wikilinks are not being reported for RTF or TXT files. Here’s a screenshot.
Ok. I can see the rational behind this. It’s interesting though, that with markdown documents, automatic links are reported in the links inspector. Maybe it could be helpful to have a settings option to chose if automatic links are to be used by the links inspector for any type of document?
In the screenshot above, I created two wiki links to the same Clutch Rummy document. I noticed if I hovered my mouse over the lower half of the first link, I got a tooltip (?) that told me where the link went to (next to the previous/next carrots near the top of the image). I can’t screen capture the mouse cursor itself, so I drew a red circle to show the approximate area where it needed to be before the link info appeared.
The issues are that on the first Clutch Rummy link, the mouse has to be over a very narrow range to get it to appear, and on the second link, it won’t appear at all, regardless of where the mouse cursor is.
Also, when I make the wiki link in an RTF document, there’s no place for the tool ip above to appear, as there is a formatting bar there. So, the question is should this info be appearing when you hover over a wiki link?
I am seeing an issue with the last link not displaying in the Navigation bar, but yes, it appears the area required to display the link is quite small and/or fiddly.
