When I first installed WordService several days ago, it worked properly. But now it doesn’t show up in my Services menu at all for Cocoa apps (CalcService does). I tried uninstalling it and removing the plist file (org.grunenberg.WordService.plist) from my preference folder.
What can I do to get it available again?
Also, does it conflict with anything in particular? I haven’t added anything new recently except for TextExpander (as a demo). Could that be it?
I did login and logout and restart before I contacted this forum and have done that several times. Still no go.
What’s really odd is that it shows up in Service Scrubber as a service to enable or disable in the service providers section but does not show up as an option in the “service menus” section.
As I said before, CalcService does.
Also, as I said, WordService did work the first day or so I had it.
I’ve since uninstalled it, removed the plist file, reinstalled it, logged out, logged in, restarted, etc. and still nothing.
I don’t get it. Would the most likely cause be a conflict with another app?
