The component
/Contents/PlugIns/OCRPlugin.bundle/Contents/Resources/DEVONscribbler.app
is not 64 bit in 2.11.2 according to Go64
https://www.stclairsoft.com/Go64/
Will you update this soon?
Best regards
François
We have already done so — in DEVONthink Pro 3. There won’t be an update that addresses this for DEVONthink 2 we’re afraid. After eleven years we have retired the version 2 product line
So, to be clear: your reply means that DEVONthink Pro Office v2 (and I assume other DEVONthink v2 editions) will not work with macOS Catalina?
No, DEVONthink 2 will work just fine. Only the OCR component of DEVONthink Pro Office will no longer work as it’s 32 bit only.
