Thanks so much for your detailed explanation and all of your help! Really appreciate it… I now understand what you mean about how to use replication within the DTP - GoodReader system that you’ve outlined. You’re right: the replication system you’ve detailed makes more sense than the one that I’ve conceived. I have an embarrassing admission… Somehow I haven’t figured out how to delete the newly annotated files, that I’ve moved back into DTP from GoodReader, without deleting both replicants! I’m sure there’s an easy solution I haven’t figured out…
As for the priority system… I tried to use the replicant system you outlined - i.e., creating a High / Medium / Low folder system within the “Sync DT” folder. But…it simply didn’t work. Yes, I could create a High / Medium / Low folder system within the individual topic folders, but that’s too much clutter and doesn’t accomplish what I’m trying to set up - i.e., just having a priority system, that approximates a replicant-like system.
I’m sorry, but I don’t understand that question. Of course you cannot delete a file in a database without deleting all the references to that file (actually, I know how to do that, it is not that difficult, but it is either a hack or an error if it occurs, not something regular). Why would you want to do that (why do you want to have references that do not refer to a file)?
Probably I missed something. So please explain in some more detail what happened and what you want to delete.
Not at all! It’s me, not you… Short answer: Just trying to figure out how to delete one replicant file - without deleting both of them. I’m sure it’s very easy…but I haven’t figured it out yet.
I don’t understand what you mean by ‘it simply didn’t work’. Did you get an error message saying “sorry we can’t do that”?
Please describe in more detail what you did and what happened. And please make a clear distinction between groups in DevonThink and folders in the Finder.
Did you replicate the entries in your priority smart groups outside the “Sync DT” group to high/medium/low groups in the “Sync DT” group as I suggested? And does "it simply didn’t work’ mean that you ended up with empty high/medium/low folders in the “Sync DT” folder in the Finder? In that case the problem might be that the relevant files are already in the topic folders.
I created the High / Medium / Low folder system in DTP - inside of the “Sync DT” folder, and separate from the topic subfolders. I then replicated the files contained in the topic folders to the High / Medium / Low folder system, depending on their priority.
The High / Medium / Low folder system that I created is not a smart group system - they’re regular folders (or groups) contained in the “Sync DT” folder - separate from the topic subfolders, but containing replicant files from these topical subfolders. So, it seems that replication doesn’t work w/ index / synced files in GoodReader.
Yes, the folders are empty - in GoodReader.
Yes, they are. So…maybe I fouled up your instructions… Or maybe there’s a way to replicate the files from outside another source into the high/medium/low folders in the “Sync DT” folder.
I am starting to feel very stupid but again I don’t understand what you are trying. What do you mean by " a priority system, that approximates a replicant-like system"?
Do you really need topic folders within your ‘Sync DT’ folder? Why? Is it because otherwise you lack an overview of what you need to do when opening GoodReader? If so isn’t it a better solution to increase your review frequency than to use topic folders?
If I’ve understood you well DevonThink is your document organization system and GoodReader is for reading and annotating? I assume that you regularly (say once in a week) determine what to read and annotate the coming period (determining what to read is what I mean by a review)?
If so, my suggestion is to set up a ‘Sync DT’ group and folder with three subgroups/folders: High, Medium, Low (and nothing else!!!). When it is time for the review open DevonThink, determine what you want to read the next week or so and replicate everything you want to read to the priority groups within ‘Sync DT’, move them to the external folder, sync GoodReader and start reading and annotating. During the next review sync GoodReader, move the files in the priority groups into the database, delete the references of the documents you’ve read and of the documents you no longer want to read, move references that have changed in priority to the priority group where they belong now and replicate references to new documents you want to read from outside the priority group to the priority groups, when you are ready move the files in the priority group to the external folder, sync GoodReader and start reading again. And so on.
This is a simple workflow that doesn’t take too much time (it could be partly automated by means of applescripts but even without automation it is not more than 10 minutes each review).
The bottom line: if DevonThink is your document organization system you don’t need and shouldn’t want to have a copy of that organization in Goodreader, it is enough to have copies of the files you want to read this week (or today if this week’s list is too long)!
Ah, that is very easy indeed (assuming that by ‘replicant file’ you mean ‘replicant’): select the replicant and hit the delete key or click on the delete button in the toolbar
Ah, as I said, replicants within indexed groups cause problems!
GoodReader is no problem, the problem is that you have two references to the same file in an indexed group in DevonThink.
Yes you fouled up my instructions (I suggested to replicate references from outside the “Sync DT” group to the priority groups), but as you already had references to those files in the ‘Sync DT’ group, you would have had the same problem if you had followed them.
The problem is that you can’t replicate files, you can only replicate references. So if you have two replicants (that is two references to the same file) within an indexed group (let’s say one is in the zoology group the other in the high group) you have a problem because the corresponding file can not be in both the zoology folder and the high folder.
However you can have as many replicants as you likeoutside the indexed group and this offers the possibility to keep your databse organized while doing your reading and annotation in GoodReader (see my previous reply).
That’s an excellent set up - and much better than the one I earlier conceived! Just out of curiosity… You mentioned that there might be a to
. What did you have in mind exactly? Also, is there a relatively easy way to create replicants while saving / importing files (so that I can quickly replicate messages into the High / Medium / Low folders that will exclusively be in the “Sync DT”)? Otherwise it seems like I’d have to saving / importing files, then navigate to them, and replicate them into the High / Medium / Low folders. Suggestions? Thanks!
I didn’t have something exactly in mind It’s just that I have the impression from what I read on blogs and forums that DevonThink has excellent AppleScript support, so it shouldn’t be too difficult. I have no experience with applescripting DevonThink, though.
As far as I know you can’t create replicants while saving or importing. But I think there are quicker ways than navigating to the relevant references. It depends on the way in which you save/import the files. For example, if you save/import the files into an inbox you can replicate the reference to a priority group before moving them to groups in your organized hierarchy.
How about a smart group with references to all the files you added last week (or today or whatever the period between reviews)? Do not put this smart group in your ‘Sync DT’ group but use it to replicate the references to your priority groups.
I understood from previous replies that you use priority labels. There is no reason to change that (the nice thing of the suggested workflow is that you can use the existing organization to determine what should be send to GoodReader). You can add the labels in the way you add them now. Create smart groups for the relevant labels and replicate the references from these smart groups to the corresponding priority groups. (I guess this can be automated easily with an AppleScript script)
Priority tags might be easier than priority labels for these can be added when clipping.
By the way: you can’t replicate messages into folders, you can only replicate to groups. This may seem a bit pedantic. I know and I do mind. Yet, I find my reputation less important than the opportunity to clear up your mind , for I have the impression that the failure to distinguish between groups and folders and between files and references is one of the main causes of your troubles with your DevonThink / GoodReader workflow.
Just wanted to thank you very much for all of your incredible help.
I hoped that there was a way to replicate the files into the High, Medium, Low priority folders, as you suggested. But it never seems to work. So, I’m thinking about following Korm’s advice, and simply apply prefixes to items that are marked as High, Medium, Low priority.
Does anyone know…
(1) If / how to create a script that would atomically apply prefixes that corresponded to certain applied labels (High, Medium, Low priority)?
(2) If / how to create a script that would atomically remove prefixes after labels have been removed?
Please, if you want help, don’t just say ‘it doesn’t work’ but add details about what went wrong.
To be sure I have now tried the setup myself and it works perfect.
I suggest that you carry out the following steps to the letter and detail any problems you encountered – if it doesn’t work, please describe exactly what you did and what happened.
Before you start, make sure that you don’t get replicants within indexed groups.
You can do this either by removing all indexed groups from your existing database before you start or by creating a new database for testing. If you do the latter: Close the old database, add a number of files to the new database, sort their references into two groups, add some replicants and label the references with the labels you normally use to indicate priorities.
Now do the following:
Create a new, empty folder ‘Sync DT with GR’ on Dropbox.
Index that folder from within DEVONthink (File > Index).
This gives you a group ‘Sync DT with GR’ within DevonThink.
Within DevonThink: create ‘High’, ‘Medium’, and ‘Low’ groups within the new ‘Sync DT with GR’ group (don’t create anything else in this group!).
In DevonThink, outside ‘Sync DT with GR’: create three smart groups, one that collects references to documents labeled ‘high’, one that collects references to documents labeled ‘medium’, one that collects references to documents labeled ‘low’. Name them ‘Label High’, ‘Label Medium’ and ‘Label Low’.
Inside DEVONthink, replicate the references in the ‘Label High’ smart group to the ‘High’ group in ‘Sync DT with GR’, those in the ‘Label Medium’ smart group to the ‘Medium’ group in ‘Sync DT with GR’, those in the ‘Label Low’ smart group to the ‘Low’ group in ‘Sync DT with GR’.
Note that you should replicate the references in the smart groups, not the smart groups themselves! Do this either by means of ‘Replicate to’ in the contextual menu (you get the contextual menu by control clicking on a reference) or by dragging the references while pressing both the option and the command key.
Inside DevonThink: move the document(s) in the ‘Sync DT with GR’ group to the ‘Sync DT with GR’ folder on Dropbox (don’t drag, choose ‘Move to External Folder’ in the contextual menu of the ‘Sync DT with GR’ group).
This moves the files from the DevonThink database to the Dropbox folder, their references in DevonThink remain where they are.
Your set up is ready (don’t change it!), start using it:
To read and annotate the documents in the ‘Sync DT with GR’ folder in GoodReader:
7a) Synchronize GoodReader with the ‘Sync DT with GR’ folder on Dropbox, read the documents and make annotations.
7b) Sync GoodReader with Dropbox to move the annotated files back to the ‘Sync DT with GR’ folder on Dropbox.
7c) Update DevonThink’s index from within DevonThink (File > Update Indexed Items) to incorporate the annotations in DevonThink’s index.
If this works fine try to make changes to the contents of the ‘Sync DT with GR’ groups (never rename, move, delete or trash files in the ‘Sync DT with GR’ folder on Dropbox and do not let GoodReader delete remote files):
To remove references from the ‘Sync DT with GR’ groups (without changing the organization of the database):
8a) From within DevonThink: move the relevant files into the DevonThink database by choosing ‘Move into database’ in the contextual menu of their references (don’t drag!).
This removes the files from Dropbox and puts them back in the DevonThink database. All references to these files in DevonThink remain where they are.
8b) To avoid confusion, delete the reference to those files from the ‘Sync DT with GR’ group (all other replicants remain where they are)
To add references from outside the ‘Sync DT with GR’ group to a ‘Sync DT with GR’ group:
9a) Check whether there already are replicants of those references in the ‘Sync DT with GR’ groups (if so: STOP – never add a replicant of a reference in ‘Sync DT with GR’ to ‘Sync DT with GR’!).
9b) Replicate the references from outside the ‘Sync DT with GR’ into the relevant ‘Sync DT with GR’ group (by means of ‘Replicate to’ in the contextual menu, or by dragging the references while pressing both the option and the command key). Don’t replicate a reference twice and don’t replicate replicants of references already replicated.
9c) Move the relevant documents in the ‘Sync DT with GR’ group to the ‘Sync DT with GR’ folder on Dropbox (‘Move to External Folder’ in the contextual menu).
To move references from a group in ‘Sync DT with GR’ to another group in ‘Sync DT with GR’:
Move the references by dragging or by means of the contextual menu
Remember: never replicate within the ‘Sync DT with GR’ group!!!
When you send a document to e.g. GoodReader this numeric file name makes it possible to identify it when you send it back to DEVONthink To Go through “Open In” mechanism. This updates the original in DEVONthink To Go without duplicating anything (except for the file in GoodReader, but there is not much that could be done here; that’s a limitation of the extreme sandboxing on iOS).
In the meantime I have experimented with scripting DevonThink and it turns out that it is indeed easy to automate the process with an applescript like this one:
-- get references to the relevant groups
set theSmartGroup to get record at "/Label High"
set theDestination to get record at "/Sync DT with GR/High"
-- get references to the content of the Smart Group
set theContent to get children of theSmartGroup
-- replicate the items in the Smart Group to the priority group
repeat with thisItem in theContent
if not (indexed of thisItem) then replicate record thisItem to theDestination
-- move the relevant files to the external folder
deconsolidate record theDestination
You can AppleScript replication with priority tags in this way:
-- specify the relevant database, tag and destination
set theDatabase to "Name of your database"
set theTag to "High"
set theDestination to "/Sync DT with GR/High"
-- get the relevant references
set theSource to lookup records with tags {theTag} in database theDatabase
set theDestination to get record at theDestination in database theDatabase
-- replicate the items in theSource to theDestination
repeat with thisItem in theSource
Two clever scripts, thank you. You might want to post a full version of of your June 26 snippet for readers who are not AppleScript adepts and might want to have a complete script to work with. Also, you might want to cross post these script ideas and examples to the Script forum so they don’t get buried in this thread.
Thanks very much for this… Just out of curiosity, how would your script function different than this one (that another DTP forum member suggested)? I don’t know a thing about AppleScript code, and so I’m just curious (before I implement either of these!). Thanks!
on triggered(theRecord)
set theSelection to the every child of theRecord
-- set theSelection to selection
set labelCount to 0
-- display dialog "DEBUG at First Setting"
repeat with thisItem in theSelection
-- display dialog "DEBUG at Inside repeat"
-- first we get rid of existing prefixes
-- "1_" == I. Urgent, "2_" == II. High, "3_" == III. Moderate
set myName to the name of thisItem
if (the name of thisItem contains "1_") then
set myName to my trim_line(myName, "1_", 0)
else if (the name of thisItem contains "2_") then
set myName to my trim_line(myName, "2_", 0)
else if (the name of thisItem contains "3_") then
set myName to my trim_line(myName, "3_", 0)
-- next we assign new prefixes, or none, based on the current label
-- label 1 == High, 2 == Medium, 3 == Low
if the label of thisItem is 1 then
set the name of thisItem to "1_" & myName
set labelCount to labelCount + 1
else if the label of thisItem is 2 then
set the name of thisItem to "2_" & myName
else if the label of thisItem is 3 then
set the name of thisItem to "3_" & myName
else
set the name of thisItem to myName
set Notified to my growlMe((labelCount as string) & " items were updated by Set Prefix Depending on Label")
end triggered
-- Attribution: this "trim_line" sub-routine was provided by
-- http://www.macosxautomation.com/applescript/sbrt/sbrt-06.html
on trim_line(this_text, trim_chars, trim_indicator)
-- 0 = beginning, 1 = end, 2 = both
set x to the length of the trim_chars
-- TRIM BEGINNING
if the trim_indicator is in {0, 2} then
repeat while this_text begins with the trim_chars
set this_text to characters (x + 1) thru -1 of this_text as string
on error
-- the text contains nothing but the trim characters
return ""
-- TRIM ENDING
if the trim_indicator is in {1, 2} then
repeat while this_text ends with the trim_chars
set this_text to characters 1 thru -(x + 1) of this_text as string
on error
return ""
return this_text
end trim_line
-- for information on scripting Growl see
-- http://growl.info/documentation/applescript-support.php
on growlMe(myNotification)
set isRunning to (count of (every process whose bundle identifier is "com.growl.growlhelperapp"))
if isRunning = 1 then
tell application id "com.growl.growlhelperapp"
set the allNotificationsList to {"Script Status", "Failure"}
set the enabledNotificationsList to {"Script Status", "Failure"}
register as application "DEVONthink Script" all notifications allNotificationsList default notifications enabledNotificationsList
notify with name "Script Status" title "DEVONthink Script Status" description myNotification application name "DEVONthink Script" with sticky
end growlMe
The script of 7 Augustrenames entries in a DevonThink database based on their label: it prefixes the names of entries that have the first label with “1_”, that have the second label with “2_” and that have the third label with “3_”
My snippet of 26 June indicates how to write a script that replicates the entries of a smart group to an indexed group and moves the corresponding files to the external folder. It isn’t a working script, only a sketch.
I posted a working script that replicates entries from three smart groups (‘Label High’, ‘Label Medium’ and ‘Label Low’) to the corresponding indexed groups (‘High’, ‘Medium’, ‘Low’) and moves the relevant files to their external folders in the ‘Replicating to indexed groups by means of AppleScript’ thread in the Scripting Forum.
Working with indexed groups is a tricky business and for that reason I suggest experimenting with the workflow as described on 31 May (21:22 and 23:22) and 3 June before starting with the script!
