Hi again,
Just wondering if there might be a new and easier way of syncing DTP with GoodReader with DTP’s new Sync function.
Any ideas or suggestions?
Thanks!
Hi again,
Thanks!
I think the sync technology only “allows you to synchronize databases”, and doesn’t sync between DEVONthink or DTTG and other apps. So, it wouldn’t improve the interaction between GoodReader and DTTG.
But, this might, if DEVONtech were interested:
Ok, thanks. It seems that it’s not something that I can configure on my own, but instead depends on DTP setting it up such functionality. Lets hope they do so!
Hi,
Just wondering if anyone has figured out if there’s another way to make DTP groups & files sync with GoodReader - perhaps through using their new sync technology or through another means (i.e., through another cloud-like service). Thanks very much…
