A problem with pending items
In the log, I saw that I had some pending items. I searched for “item: pending” and discovered that I had several hundred pending files. I checked the sync with my iPad (Bonjour) and saw that everything appeared to be in sync. It is not possible to download the files manually.
I searched for the specific names of some of the pending items and found that almost all of them were already in the database. In other words, a search returned two documents: one marked as pending and one that was already present.
My questions are:
• To avoid this happening in the future: how did this happen? Is there anything I can do to prevent it?
• I would like to delete the pending items for documents that are already in the database. Searching for every single one of them by name would be tedious. Is there an easy way to do this—for example, with a script?
Any help would be much appreciated!
  • Are you importing or indexing?
    • If so, from where in the Finder?
  • Are you syncing with DEVONthink To Go?
    • If so, with what version?
      • If version 4, does this database pre-date version 4, possibly even going back to version 2?
    • Are you using a shallow sync in DEVONthink To Go?
