In the spirit of “there cant be to many backups” TM i want to automatically duplicate a group (full of Markdown files) within a Devonthink database into an external dropbox AND/OR iCloud (as i said cant have to many backups )
Whats the way one should approach this? should i use a smart rule? Applescript, external automation (a-la Keyboard Maestro ?)?
i want to this to happen automatically after a few minutes when i add a new Markdown files into the Devonthink group.
PS i don’t want these files to be indexed in DT at all, just have them as a backup
thx in advance, any tips would be greatly appreciated!
Whilst I’m not sure of the value of this backup (you are not insured against changes to files, only against file deletion; unless, that is, your backup destination has some kind of versioning), but I think I would go about it with a script run by a smart rule. I know of no trigger which would run a number of minutes after you add a file, other than one which simply runs every 5 minutes.
The requisite script would be something along the lines of getting the (POSIX) path to the record, telling Finder to duplicate that file to a specified location (either replacing or not replacing files with the same name in the destination) and repeating for each record. You could perform the duplicate action to a folder named (automatically) based on the date, or the day of the month, which would give you a degree of file history.
yeah as i said i plan on using dropbox as the destination so it will have rudimentary versioning. i also will consider perhaps putting that MD folder in a git folder and manually push changes
yeah every X minutes will work great!
Problem is i don’t know how to code … i can however try to follow Applescript/BASH examples (…sometimes … ) and slightly modify them to suit my needs. Do you know if there are script examples for such an export to a destination? either by the community or developers? i googles but couldn’t find something along theses lines
property targetFolder : "/Users/yourUserName/Downloads/DTbackup" -- use a path such as "/Users/yourUserName/Documents/aFolder"; if you open a location in Finder, you can copy the path by right-clicking the destination in the path bar (the path bar can be toggled on/off in the View menu); paste it here, putting it in quotes
property replaceFiles : true -- use true or false to determine whether files with the same name in the destination should be overwritten (true) or not (false).
show progress indicator "Duplicating files to Backup" cancel button 1 steps count of theRecords
do shell script "mkdir -p " & quoted form of targetFolder
if cancelled progress then error number -128
step progress indicator (name of theRecord) as string
set theFile to path of theRecord as text
if replaceFiles is true then
tell application "Finder" to duplicate (theFile as POSIX file) to folder (targetFolder as POSIX file) with replacing
else
tell application "Finder" to duplicate (theFile as POSIX file) to folder (targetFolder as POSIX file) without replacing
hide progress indicator
end performSmartRule
Note that you need to specify the folder you want the files duplicated to in the first line; the comment explains how to do so. Also, you need to specify whether files should be overwritten or not. Note that the destination you specify will be created if it does not exist.
The script will not create any other form of structure, i.e. the records provided by your smart rule will be duplicated to the destination and no additional folder tree will be created. It would probably be possible to expand the script to replicate the structure in DT (i.e. Database/Group/Subgroup) if necessary.
As always: please try this on test files first and determine for yourself whether it does what you require it to do.
This adapted version optionally saves the files to your target folder including a folder tree based on the name of the database and the location of the file within that database, so to yourdestination/database/group/subgroup/subgroup/file. Just in case that is helpful to you or others passing by here.
property targetFolder : "/Users/Michael/Downloads/DTdest" -- use a path such as "/Users/yourUserName/Documents/aFolder"; if you open a location in Finder, you can copy the path by right-clicking the destination in the path bar (the path bar can be toggled on/off in the View menu); paste it here, putting it in quotes
property includePath : true -- use true or false to determine whether the destination path includes the group structure (true) or not (false)
if includePath is true then
set destFolder to targetFolder & "/" & name of database of theRecord & location of theRecord
else
do shell script "mkdir -p " & quoted form of destFolder
tell application "Finder" to duplicate (theFile as POSIX file) to folder (destFolder as POSIX file) with replacing
else
tell application "Finder" to duplicate (theFile as POSIX file) to folder (destFolder as POSIX file) without replacing
Edit: Oh, and DT has an AppleScript function called export which looks like it would do much the same thing - so it would be possible to avoid calling “Finder”, although it’s not obvious to me that we could then determine whether or not files should be overwritten. All roads lead to Rome.
