You should not be reinstalling the software trying to resolve such issues, with any application. It rarely fixes anything and also removes information useful to support. Reinstallation is a last resort, not a first one.
if you are trying to use a local LLM for DT help, one thing I’ve done is created a group just for that purpose and put the DT manual there. Then I select the manual and ask my questions to the LLM as I would any other documents
I tried the various options and found that the remote-based AI models, Ollama (remote) and OpenAI (Compatible), also cannot be used in DEVONthink Help. Is this normal? Is there a plan to make these compatible with DEVONthink Help in the future?
Local models vary wildly in their capabilities (and tendencies to hallucinate) and the three commercial models present known entities we can fine-tune with. So while it may happen, it wouldn’t be simply done.
